New build.
Post Number:#21 Post Sat Sep 27, 2014 12:37 am
OK so at this point I am stumped, I have tried every different way of inserting the code I have tried different codes with shield without shield on a Mega board with the shield and nothing but a white screen. ~x(
Post Number:#22 Post Sat Sep 27, 2014 9:50 am
Using the code below try:
1º Check if have ~ 4.5 V on pins 3 - 7, 22 - 41 and 50 - 53;
2º Check if have ~ 3.3 V in all pins else to GND and NC on connector 2 x 20.
  for(int i = 3; i < 8; i++)
    pinMode(i, OUTPUT);
    digitalWrite(i, HIGH);
  for(int i = 22; i < 42; i++)
    pinMode(i, OUTPUT);
  for(int i = 50; i < 54; i++)
    pinMode(i, OUTPUT);
Post Number:#23 Post Sun Sep 28, 2014 5:25 am
Post Number:#24 Post Sun Sep 28, 2014 7:17 am
Hi Fernando
Thank you for the help the screen is working now, not shure what I did but it's working, touch is another story though . The calibration code will not work without the shield, button test doesn't work at all. I will keep trying different codes till I find one that works I don't wantbe a bother to you as know you are busy, thanks again for the help and best wishes.
-------------------------------- Last edited Sun Sep 28, 2014 3:18 am --------------------------------
Hi Fernando
Ok so I got the screen to work with the new UTFT code, just waiting on my parts for set up.
Post Number:#25 Post Sun Sep 28, 2014 11:38 am
Change:
UTouch      myTouch(6,5,4,3,2);
UTouch      myTouch(7,6,5,4,3);
What happens with your posts?
Post Number:#26 Post Sun Sep 28, 2014 11:53 am
Ok I will try that. After I wake up this afternoon, I work over nights thats why my posts are so far apart.
Post Number:#27 Post Sun Sep 28, 2014 11:55 am
But why are duplicated?
Post Number:#28 Post Mon Sep 29, 2014 3:14 am
Not sure why they are double post on some maybe because they were edited, any how I tried to load Ferduino code and had some errors come up.
Ferduino_English_1.cpp.o: In function `setFont(unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char)':
C:\Users\User\Desktop\controller master files\arduino-1.0.6/Botoes_e_etc.ino:212: undefined reference to `RusFont1'
Ferduino_English_1.cpp.o: In function `Grafico_WaveMaker()':
C:\Users\User\Desktop\controller master files\arduino-1.0.6/Wavemaker.ino:42: undefined reference to `RusFont1'
Ferduino_English_1.cpp.o: In function `printButton_vermelho(char*, int, int, int, int, unsigned char)':
Ferduino_English_1.cpp:(.text._Z20printButton_vermelhoPciiiih+0xca): undefined reference to `RusFont1'
Ferduino_English_1.cpp.o:Ferduino_English_1.cpp:(.text._Z20printButton_vermelhoPciiiih+0xcc): more undefined references to `RusFont1' follow
Post Number:#29 Post Mon Sep 29, 2014 8:18 am
In .../libraries/UTFT delete the file "DefaultFonts.c"
In .../Ferduino_English/bibliotecas/UTFT copy the files "BigFont.c", "RusFont1.c", "SmallFont.c", " SevenSegNumFont.c", "SevenSegmentFull.c" and "SevenSegNumFontPlus.c" paste in .../libraries/UTFT.
Post Number:#30 Post Mon Sep 29, 2014 7:51 pm
Post Number:#31 Post Wed Oct 01, 2014 4:09 pm
some where in you talks you had mentioned changing some settings to make touch work with different settings so touch will work do you know what post it was in, all I can remember is a setting changed to -399
Post Number:#32 Post Fri Oct 03, 2014 1:05 pm
Post Number:#33 Post Mon Oct 06, 2014 5:01 pm
I'm sorry but, can't help you because I haven't a TFT 4.3".
Post Number:#34 Post Tue Oct 07, 2014 1:48 am
Not an issue I will continue to work on it I am getting close to a solution once I get it figured out I will post code so that others who want to use can.
-------------------------------- Last edited Mon Oct 06, 2014 9:48 pm --------------------------------
Post Number:#35 Post Tue Nov 04, 2014 7:42 am
Ok so I got some time and I have got the touch screen to on calibration but once I load ferduino it doesn't work again. I have checked to make sure settings are right uncomment 7, 6, 5, 4, 3 and on the home screen it goes to password screen when touched but can't enter password like touch quit working again . I have gone through the code and don't see anything strange.
Post Number:#36 Post Tue Nov 04, 2014 8:54 am
You saw this topic?
Have you changed:
const byte ChipSelect_SD = 4;
to:
const byte ChipSelect_SD = 5;
Post Number:#37 Post Wed Nov 05, 2014 3:47 am
Post Number:#38 Post Thu Nov 06, 2014 4:34 pm
Hi Fernando.
Which 2 wires do you use for the temp probes and also I will be working on code for 16 relay control any advice. B-)
Post Number:#39 Post Thu Nov 06, 2014 4:43 pm
Post Number:#40 Post Fri Nov 07, 2014 1:34 am
well something bad just happened, no communication with the board it times out every time ~x(
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
I was connecting 16 relay board when the problem occurred to Relays-2 connector.
PreviousNext
