New build.
Post Number:#161 Post Fri Feb 13, 2015 10:05 am
As soon as I plug in EC stamp the board starts to glitch and tries to lock up if I reset withthe stamp on the board it will not turn back on, like hitting reset over and over.
Post Number:#162 Post Fri Feb 13, 2015 10:11 am
Atlas changed the default baud rate to 9600.
Using test code change to 38400.
Send:
SERIAL,38400
Post Number:#163 Post Fri Feb 13, 2015 10:41 am
Ok thank you, I will try that after I drop my girls off at school.
-------------------------------- Last edited Fri Feb 13, 2015 7:58 am --------------------------------
Hi Fernando I just looked at your post with Rubin and I do not have the EZO selection in Ferduino tab, do I need to download new program from web?
Post Number:#164 Post Fri Feb 13, 2015 11:17 am
No, only copy this code: viewtopic.php?f=8&t=187
Maybe you already have this code.
Post Number:#165 Post Wed Feb 18, 2015 6:12 am
Is there something in the code that has to be turned on for the dosing pumps to run automatically I have set them in custom screen for every day 60 ml over 4 dosing period and made sure they were on, but I don't they are working, I tested manually to make sure the circuit was and it works.
Post Number:#166 Post Wed Feb 18, 2015 8:39 am
You need make a mark on reservoir to see if is emptying according to your dosage.
To test custom dosage, select an interval of 10 minutes and 1 dose then, wait to see if it works. The dosage will happen after 5 minutes.
Post Number:#167 Post Wed Feb 18, 2015 9:19 am
Okay thank you I will try that when I get home from work, also I am doing more testing to find what happened when the board got shorted, so far I have found a bad network resistor and will replace it today. Is there a way to put a fuse on the ground side to keep this from happening?
Post Number:#168 Post Wed Feb 18, 2015 9:31 am
Put the fuse between power supply and power connector.
Post Number:#169 Post Sat Feb 21, 2015 10:30 pm
bulk reef supply has a titanium rod to put in sump and connect to ground to help with stray voltage issues,I ordered one and will see what the results are. I also figured out my light issues I did not have a negative going back to ferduino from 5up board b-(
Post Number:#170 Post Sun Feb 22, 2015 10:11 am
A ground probe is useful to prevent shock too. Let me know the result.
You need give the feedback about LEDs on other topic and mark as solved.
Post Number:#171 Post Mon Feb 23, 2015 12:33 am
Post Number:#172 Post Thu Feb 26, 2015 1:30 pm
Still waiting on the ground rod from BRS. but did some other things in the mean time got the LED lights running, dosing pumps are all set up and ready to go, I did get a new EC stamp but I cannot use it till I figure out why the other one blew up same with the ORP stamp. Fernando this one is for you,I was checking the coolers jack witch should have 2 GRND by your schematics but one those GRND is live could that be the same line that is shorting out my stamps and the TX side of the Ethernet?
Post Number:#173 Post Thu Feb 26, 2015 2:31 pm
Only 1 GND live is impossible because all are connected.
Look to PCB design:
Post Number:#174 Post Fri Feb 27, 2015 7:34 pm
Post Number:#175 Post Sat Feb 28, 2015 8:18 pm
ph and temp readings are all stable now with the grounding rod from BRS. Is it okay to post a link for it?
Post Number:#176 Post Sun Mar 01, 2015 11:35 am
Feel free to post the link.
Post Number:#177 Post Sun Mar 01, 2015 12:01 pm
Post Number:#178 Post Mon Mar 02, 2015 6:37 am
Topics: 12
Topics: 12
Netherlands
Post Number:#179 Post Mon Mar 02, 2015 10:36 am
Topics: 12
Topics: 12
Netherlands
Post Number:#180 Post Tue Mar 03, 2015 12:03 am
PreviousNext
