New build.
Post Number:#121 Post Thu Jan 29, 2015 9:05 am
Yes I have a female RJ45 on my dosing pump box and made a cable to connect, plus line to bring 12 volt to dosing pump.
Post Number:#122 Post Sat Jan 31, 2015 12:30 am
Hi Fernando, I was wondering if I could use a data logging shield for sd card in stead of tft as I want to make a small enclosure for the display. :-?
-------------------------------- Last edited Fri Jan 30, 2015 10:02 pm --------------------------------
four dosing pump setup will eventually be 6 pumps.
Post Number:#123 Post Sat Jan 31, 2015 8:05 am
Is more easy leave a hole for SD card like this:
Post Number:#124 Post Sat Jan 31, 2015 8:11 am
good morning Fernando, ok I will change where I was going to mont the screen, can you tell me what float switchs go where I thought that there was picture with diagram but I cannot find it I have looked all over the forum and don't see it anywhere?
and are my pichters posting at a better size now?
Post Number:#125 Post Sat Jan 31, 2015 8:15 am
On Portal have a block with many links search for "Where to start?" and you'll see the link for part list.
No, the images are small and now are duplicated. =))
Post Number:#126 Post Sat Jan 31, 2015 8:19 am
Post Number:#127 Post Sat Jan 31, 2015 8:24 am
If you need help to resize images PM me.
Post Number:#128 Post Sat Jan 31, 2015 8:27 am
I think float switchs 1 and 2 are for the sump, 3 and 4 goto ATO res and where do 5 and 6 goto?
I resized to 1028x768 with format factory, should size be different?
Post Number:#129 Post Sat Jan 31, 2015 8:32 am
Post Number:#130 Post Sat Jan 31, 2015 8:40 am
thank you. Most of my pictures are with a web cam, I will check the setings when I get home.
What are switch 5 and 6 used for?
Post Number:#131 Post Sat Jan 31, 2015 9:44 am
Are used on tanks, I have two. Is to detect leaks.
Post Number:#132 Post Sat Jan 31, 2015 10:05 am
Ok I see thank you for clarification.
-------------------------------- Last edited Sat Jan 31, 2015 7:10 am --------------------------------
What kind of solenoid do have on your setup, they do not have metal?
Post Number:#133 Post Sat Jan 31, 2015 10:26 am
Can be any model used for washer clothes. It's for fresh water so, no problem.
The mine is in serie with a float valve. Redundancy never is too much. :D
Post Number:#134 Post Sat Jan 31, 2015 10:40 am
I would have never thought about using a washer valve, I was always looking for solenoid ball valve.
-------------------------------- Last edited Sat Jan 31, 2015 7:47 am --------------------------------
Post Number:#135 Post Sat Jan 31, 2015 10:53 pm
Is the green board in the picture a separate pcb for the atlas stamps? in post #111
Dale
If the probes are on sump, maybe you have problem of electric noise.
Check page 10 of this datasheet: http://atlas-scientific.com/_files/_dat ... asheet.pdf?
So, you need of galvanic isolator: http://atlas-scientific.com/product_pag ... r-iso.html
I did a small shield to place this isolator.
Image: http://www.ferduino.com/forum/gallery/image.php?album_id=11&image_id=258
I sent the project to Sueur Aurelien and he bought 10 PCB's, send a PM to him and ask if can sell a piece for you.
Post Number:#136 Post Sat Jan 31, 2015 11:56 pm
Post Number:#137 Post Sun Feb 01, 2015 5:43 am
Topics: 12
Topics: 12
Netherlands
Post Number:#138 Post Sun Feb 01, 2015 8:27 pm
It helps to isolate any electric noise coming from pumps and other items in the water, if you do not have that issue then it is not need.
Post Number:#139 Post Tue Feb 03, 2015 1:25 am
Hi Fernando it says level on the home screen, what is that tracking because no matter what I do it is always low.
Post Number:#140 Post Tue Feb 03, 2015 8:44 am
For default code the normal status is this:
If you want change the function look to tab "parametros" on "void check_nivel()".
PreviousNext
