Forum Members section Show your controller My build.
My build.
Post Number:#41 Post Thu Feb 05, 2015 7:43 pm
Topics: 12
Topics: 12
Netherlands
Post Number:#42 Post Thu Feb 05, 2015 7:46 pm
Post Number:#43 Post Thu Feb 05, 2015 8:11 pm
Topics: 12
Topics: 12
Netherlands
Tnx it took me a while before i figured out you have to run these commands with the stamp testcode. But it worked it is running at 38400 now :)
Post Number:#44 Post Fri Feb 06, 2015 1:13 pm
Just to clarify,
Atlas have changed the default baud rate to 9600. I'm sorry was looking to old datasheet.
Post Number:#45 Post Fri Feb 06, 2015 3:49 pm
Topics: 12
Topics: 12
Netherlands
Post Number:#46 Post Tue Feb 24, 2015 6:31 pm
Topics: 12
Topics: 12
Netherlands
Everything is still working great. I added a ph stamp. I can now make my aquarium cooler fan run when it get's to hot. And i added a 433 transmit module to the ferduino so I can switch on my wireless power sockets in my home (klik aan klik uit). I can now switch on remote my hd-camera to have a nice life feed of my aquarium, and see if my flow pump is running. I am actually done now. Evertything is working exactly how i want it too. So what i have is:
3 temp probes running
1 ezo ph stamp running
1 cooler fan running when it get's to hot.
1 float switch that get's triggerd if my return pump stops (send an ph reactor alert to my e-mail)
1 433 wireless communication to power sockets that now controll my hd internet camera.
So fernando thank you for bringing this awesome product.
Post Number:#47 Post Tue Feb 24, 2015 6:36 pm
Some pictures and video should be nice. :)
Post Number:#48 Post Tue Feb 24, 2015 7:13 pm
Topics: 12
Topics: 12
Netherlands
I will see if i can make some nice pictures tomorrow. I have one thing i would like to fix but it is just for the niceness of it. I still have a littebit noise on my ph readings (see picture or click link):
https://dyp.im/fIiN6fj5w9
The max of those reading is correct i testes this with my other ph measurement. So i would want to take say 10 readings and then only use the max of those 10 readings. That way I would filter out the noise. Any tips on how to go with that idea, or maybe you have a different idea?
Post Number:#49 Post Tue Feb 24, 2015 9:56 pm
Some time ago I did a code to remove delay and use a average of 8 values but, I had not good results using all stamps together.
Maybe it can help you.
The code is to stamps V 4.x, adjust for EZO.
The code take 23 values but, discards 15.
[codebender]https://codebender.cc/embed/sketch:87876[/codebender]
Post Number:#50 Post Wed Feb 25, 2015 10:39 am
Topics: 12
Topics: 12
Netherlands
I am trying all day but I can't get your code to work with the ezo stamps. This is my modified code. I first only want to use ph so i removed all the extra code. Plus don't mind all the println, I use those to test how far my code goes.
const int multiplexadorS0Pin = 16; // S0
const int multiplexadorS1Pin = 17; // S1
byte ph1 = 0; // Y0
byte ph2 = 1; // Y1
byte orp = 2; // Y2
byte ec = 3;  // Y3
int ORP = 0;
int DEN = 0;
float PHA = 0.0;
float PHR = 0.0;
long millis_antes = 0;
  Serial.begin(38400);
  Serial3.begin(38400);
  Serial.println("I'm alive!");
  Serial.println();
  pinMode(multiplexadorS0Pin, OUTPUT);
  pinMode(multiplexadorS1Pin, OUTPUT);
  StartStampTankPH();
  if((millis() - millis_antes) >= 10000)
     Serial.println("testing loop");
    CheckTankPH();
    millis_antes = millis();
    Serial.println("  ******************************  ");
    Serial.println();
void CheckTankPH()
  boolean done = false;
  char inData[150];
  char *inParse[150];
  int index = 0;
  int contador = 0;
  boolean stringComplete = false;
  char *str;
  int count = 0;
  Serial.println("stage1");
  do{
    Open_channel(ph1);
    delay(50);
    while(Serial3.available())
      char c = Serial3.read();
    Serial3.print('\r');
    Serial.println("stage2");
    delay(1000);
    Serial3.print("R"); // Envia um comando.
    Serial.println("stage3");
    delay(1000);
     Serial.println("stage4");
    if (Serial3.available()>3)
      char inChar = Serial3.read();
      inData[index] = inChar;
      index++;
      Serial.println("stage5");
      if (inChar == '\r')
        contador ++;
      if(contador == 23)
        inData[index] = '\0';
        contador = 0;
        stringComplete = true;
  while(stringComplete == false);
   Serial.println("stage6");
  for (int i= 0; i <= index; i++)
    if (inData[i] == '\r')
      inData[i] = ',';
  char *p = inData;
  if (stringComplete == true)
    while ((str = strtok_r(p, ",", &p)) != NULL)
      inParse[count] = str;
      count++;
    PHA = 0;
    for(int i= 13; i < 21; i++)
      PHA += atof(inParse[i]);
    PHA /= 8;
    Serial.print("Tank pH: ");
    Serial.print(PHA);
    Serial.print(", Values = [");
    Serial.print(inParse[13]);
    Serial.print(", ");
    Serial.print(inParse[14]);
    Serial.print(", ");
    Serial.print(inParse[15]);
    Serial.print(", ");
    Serial.print(inParse[16]);
    Serial.print(", ");
    Serial.print(inParse[17]);
    Serial.print(", ");
    Serial.print(inParse[18]);
    Serial.print(", ");
    Serial.print(inParse[19]);
    Serial.print(", ");
    Serial.print(inParse[20]);
    Serial.println("]");
    Serial.println();
 while (done == true);
void StartStampTankPH()
  Open_channel(ph1); // Open channel for tank pH
  delay(50);
  Serial3.print("R"); // To get a value
  delay(1000);
  Serial3.print("C,0"); // To stop continuous reading
  delay(1000);
  Serial3.print("L,0"); // To turn off the LEDs of debug
  delay(1000);
  Serial3.print("RESPONSE,0"); // To disable response code
  delay(1000);
void Open_channel(short channel)
  switch (channel)
  case 0:
    //open channel Y0
    //S0=0
    //S1=0
    digitalWrite(multiplexadorS0Pin, LOW);
    digitalWrite(multiplexadorS1Pin, LOW);
    break;
  case 1:
    //open channel Y1
    //S0=1
    //S1=0
    digitalWrite(multiplexadorS0Pin, HIGH);
    break;
  case 2:
    //open channel Y2
    //S0=0
    //S1=1
    digitalWrite(multiplexadorS1Pin, HIGH);
    break;
  case 3:
    //open channel Y3
    //S0=1
    //S1=1
    break;
  return;
Post Number:#51 Post Wed Feb 25, 2015 1:08 pm
Try learn how it works firstly, it isn't copy and paste only.
My code is using reading continuous so, you can't send a "R" on loop or "C,0" on setup.
Try this:
byte ph1 = 0; // Y0
byte ph2 = 1; // Y1
byte orp = 2; // Y2
byte ec = 3;  // Y3
int ORP = 0;
int DEN = 0;
float PHA = 0.0;
float PHR = 0.0;
  Serial.println();
  StartStampTankPH();
    CheckTankPH();
    Serial.println();
void CheckTankPH()
  char inData[150];
  char *inParse[150];
  int index = 0;
  int contador = 0;
  char *str;
  int count = 0;
  do{
    Open_channel(ph1);
    delay(50);
      index++;
      if (inChar == '\r')
        contador ++;
      if(contador == 23)
        contador = 0;
      inData[i] = ',';
  char *p = inData;
      count++;
    PHA = 0;
    PHA /= 8;
    Serial.print(PHA);
    Serial.print(", ");
    Serial.print(", ");
    Serial.print(", ");
    Serial.print(", ");
    Serial.print(", ");
    Serial.print(", ");
    Serial.print(", ");
    Serial.println();
  delay(50);
  delay(1000);
  Serial3.print("C,1"); // To enable continuous reading
  delay(1000);
  delay(1000);
  delay(1000);
  switch (channel)
  case 0:
    //open channel Y0
    //S0=0
    //S1=0
    break;
  case 1:
    //open channel Y1
    //S0=1
    //S1=0
    break;
  case 2:
    //open channel Y2
    //S0=0
    //S1=1
    break;
  case 3:
    //open channel Y3
    //S0=1
    //S1=1
    break;
  return;
Best regrads.
Post Number:#52 Post Wed Feb 25, 2015 2:26 pm
Topics: 12
Topics: 12
Netherlands
Post Number:#53 Post Wed Feb 25, 2015 2:43 pm
Try change the interval maybe 10 seconds isn't enough to EZO stamp.
Post Number:#54 Post Wed Feb 25, 2015 3:18 pm
Topics: 12
Topics: 12
Netherlands
I got it working now :) . Now to integrate it in the main code.
-------------------------------- Last edited Wed Feb 25, 2015 4:35 pm --------------------------------
For others this is the working code for the newest ph stamp:
byte ph1 = 0; // Y0
byte ph2 = 1; // Y1
byte orp = 2; // Y2
byte ec = 3;  // Y3
int ORP = 0;
int DEN = 0;
float PHA = 0.0;
float PHR = 0.0;
  Serial.println();
  StartStampTankPH();
  //StartStampReactorPH();
  //StartStampORP();
    CheckTankPH();
    //CheckReactorPH();
    //CheckORP();
    Serial.println();
void CheckTankPH()
  char inData[150];
  char *inParse[150];
  int index = 0;
  int contador = 0;
  char *str;
  int count = 0;
  Open_channel(ph1);
  delay(50);
  do
      index++;
      if (inChar == '\r')
        contador ++;
      if(contador == 23)
        contador = 0;
      inData[i] = ',';
  char *p = inData;
      count++;
    PHA = 0;
    PHA /= 8;
    Serial.print(PHA);
    Serial.print(", ");
    Serial.print(", ");
    Serial.print(", ");
    Serial.print(", ");
    Serial.print(", ");
    Serial.print(", ");
    Serial.print(", ");
    Serial.println();
void CheckReactorPH()
  char inData[150];
  char *inParse[150];
  int index = 0;
  int contador = 0;
  char *str;
  int count = 0;
  Open_channel(ph2);
  delay(50);
  do
      index++;
      if (inChar == '\r')
        contador ++;
      if(contador == 23)
        contador = 0;
      inData[i] = ',';
  char *p = inData;
      count++;
    PHR = 0;
      PHR += atof(inParse[i]);
    PHR /= 8;
    Serial.print("Reactor pH: ");
    Serial.print(PHR);
    Serial.print(", ");
    Serial.print(", ");
    Serial.print(", ");
    Serial.print(", ");
    Serial.print(", ");
    Serial.print(", ");
    Serial.print(", ");
    Serial.println();
void CheckORP()
  char inData[150];
  char *inParse[150];
  int index = 0;
  int contador = 0;
  char *str;
  int count = 0;
  Open_channel(orp);
  delay(50);
  do
      index++;
      if (inChar == '\r')
        contador ++;
      if(contador == 23)
      inData[i] = ',';
  char *p = inData;
      count++;
    ORP = 0;
      ORP += atoi(inParse[i]);
    ORP /= 8;
    Serial.print("ORP: ");
    Serial.print(ORP);
    Serial.print(", ");
    Serial.print(", ");
    Serial.print(", ");
    Serial.print(", ");
    Serial.print(", ");
    Serial.print(", ");
    Serial.print(", ");
    Serial.println();
  Open_channel(ph1); // Tank pH
  delay(1000);
  delay(1000);
 delay(1000);
void StartStampReactorPH()
  Open_channel(ph2); // Reactor pH
  delay(50);
  Serial3.print("E");
  delay(1000);
  Serial3.print("L0");
  delay(1000);
  Serial3.print("C");
void StartStampORP()
  Open_channel(orp); // ORP
  delay(50);
  Serial3.print("E");
  delay(1000);
  delay(1000);
  Serial3.print("C");
  switch (channel)
  case 0:
    //open channel Y0
    //S0=0
    //S1=0
    break;
  case 1:
    //open channel Y1
    //S0=1
    //S1=0
    break;
  case 2:
    //open channel Y2
    //S0=0
    //S1=1
    break;
  case 3:
    //open channel Y3
    //S0=1
    //S1=1
    break;
  return;
Post Number:#55 Post Wed Feb 25, 2015 3:36 pm
This code isn't ready to make what you told above.
You need sort values to discard the bad values.
Post Number:#56 Post Wed Feb 25, 2015 4:02 pm
Topics: 12
Topics: 12
Netherlands
Fernando I integrated the code in my main code. And now it looks like my ph readings are steady now. Will monitor the next couple of days. I decided to take the average of 10 readings instead of 8. will monitor with my other ph reader also so i know the offset and incorporate that.
Post Number:#57 Post Thu Feb 26, 2015 7:54 am
Topics: 12
Topics: 12
Netherlands
Here are some pics. I use a 3 euro curver storage box that i hacked up. cheap and splash water proof and easy accesible.
Last edited by Fernando Garcia on Thu Feb 26, 2015 9:46 am, edited 1 time in total.
Reason: Image fixed
Post Number:#58 Post Fri Feb 27, 2015 6:17 am
Topics: 12
Topics: 12
Netherlands
This is my ph curve after i made the change to the new code, much better :) .
Last edited by Fernando Garcia on Fri Feb 27, 2015 9:17 am, edited 1 time in total.
Reason: Image fixed
Post Number:#59 Post Fri Feb 27, 2015 9:22 am
Glad to hear.
To post images copy link from "Image-URL" instead "Image BBCode".
I'm curious to know what you did to control your webcam using Ferduino.
Post Number:#60 Post Fri Feb 27, 2015 9:40 am
Topics: 12
Topics: 12
Netherlands
I bought a 720p wireless ip cam which has a built in webserver. I use ferduino to control it's powersocket throuhg 433 wireless. So i use ferduino to turn the camera off and on from everywhere in het word. I only want the camera to be on when i want to check the tank. For the rest it has to be of.
