const int multiplexadorS0Pin = 16; // S0
const int multiplexadorS1Pin = 17; // S1
byte ph1 = 0; // Y0
byte ph2 = 1; // Y1
byte orp = 2; // Y2
byte ec = 3; // Y3
int ORP = 0;
int DEN = 0;
float PHA = 0.0;
float PHR = 0.0;
long millis_antes = 0;
Serial.begin(38400);
Serial3.begin(38400);
Serial.println("I'm alive!");
Serial.println();
pinMode(multiplexadorS0Pin, OUTPUT);
pinMode(multiplexadorS1Pin, OUTPUT);
StartStampTankPH();
if((millis() - millis_antes) >= 10000)
Serial.println("testing loop");
CheckTankPH();
millis_antes = millis();
Serial.println(" ****************************** ");
Serial.println();
void CheckTankPH()
boolean done = false;
char inData[150];
char *inParse[150];
int index = 0;
int contador = 0;
boolean stringComplete = false;
char *str;
int count = 0;
Serial.println("stage1");
do{
Open_channel(ph1);
delay(50);
while(Serial3.available())
char c = Serial3.read();
Serial3.print('\r');
Serial.println("stage2");
delay(1000);
Serial3.print("R"); // Envia um comando.
Serial.println("stage3");
delay(1000);
Serial.println("stage4");
if (Serial3.available()>3)
char inChar = Serial3.read();
inData[index] = inChar;
index++;
Serial.println("stage5");
if (inChar == '\r')
contador ++;
if(contador == 23)
inData[index] = '\0';
contador = 0;
stringComplete = true;
while(stringComplete == false);
Serial.println("stage6");
for (int i= 0; i <= index; i++)
if (inData[i] == '\r')
inData[i] = ',';
char *p = inData;
if (stringComplete == true)
while ((str = strtok_r(p, ",", &p)) != NULL)
inParse[count] = str;
count++;
PHA = 0;
for(int i= 13; i < 21; i++)
PHA += atof(inParse[i]);
PHA /= 8;
Serial.print("Tank pH: ");
Serial.print(PHA);
Serial.print(", Values = [");
Serial.print(inParse[13]);
Serial.print(", ");
Serial.print(inParse[14]);
Serial.print(", ");
Serial.print(inParse[15]);
Serial.print(", ");
Serial.print(inParse[16]);
Serial.print(", ");
Serial.print(inParse[17]);
Serial.print(", ");
Serial.print(inParse[18]);
Serial.print(", ");
Serial.print(inParse[19]);
Serial.print(", ");
Serial.print(inParse[20]);
Serial.println("]");
Serial.println();
while (done == true);
void StartStampTankPH()
Open_channel(ph1); // Open channel for tank pH
delay(50);
Serial3.print("R"); // To get a value
delay(1000);
Serial3.print("C,0"); // To stop continuous reading
delay(1000);
Serial3.print("L,0"); // To turn off the LEDs of debug
delay(1000);
Serial3.print("RESPONSE,0"); // To disable response code
delay(1000);
void Open_channel(short channel)
switch (channel)
case 0:
//open channel Y0
//S0=0
//S1=0
digitalWrite(multiplexadorS0Pin, LOW);
digitalWrite(multiplexadorS1Pin, LOW);
break;
case 1:
//open channel Y1
//S0=1
//S1=0
digitalWrite(multiplexadorS0Pin, HIGH);
break;
case 2:
//open channel Y2
//S0=0
//S1=1
digitalWrite(multiplexadorS1Pin, HIGH);
break;
case 3:
//open channel Y3
//S0=1
//S1=1
break;
return;
byte ph1 = 0; // Y0
byte ph2 = 1; // Y1
byte orp = 2; // Y2
byte ec = 3; // Y3
int ORP = 0;
int DEN = 0;
float PHA = 0.0;
float PHR = 0.0;
Serial.println();
StartStampTankPH();
CheckTankPH();
Serial.println();
void CheckTankPH()
char inData[150];
char *inParse[150];
int index = 0;
int contador = 0;
char *str;
int count = 0;
do{
Open_channel(ph1);
delay(50);
index++;
if (inChar == '\r')
contador ++;
if(contador == 23)
contador = 0;
inData[i] = ',';
char *p = inData;
count++;
PHA = 0;
PHA /= 8;
Serial.print(PHA);
Serial.print(", ");
Serial.print(", ");
Serial.print(", ");
Serial.print(", ");
Serial.print(", ");
Serial.print(", ");
Serial.print(", ");
Serial.println();
delay(50);
delay(1000);
Serial3.print("C,1"); // To enable continuous reading
delay(1000);
delay(1000);
delay(1000);
switch (channel)
case 0:
//open channel Y0
//S0=0
//S1=0
break;
case 1:
//open channel Y1
//S0=1
//S1=0
break;
case 2:
//open channel Y2
//S0=0
//S1=1
break;
case 3:
//open channel Y3
//S0=1
//S1=1
break;
return;
. Now to integrate it in the main code. const int multiplexadorS0Pin = 16; // S0
byte ph1 = 0; // Y0
byte ph2 = 1; // Y1
byte orp = 2; // Y2
byte ec = 3; // Y3
int ORP = 0;
int DEN = 0;
float PHA = 0.0;
float PHR = 0.0;
Serial.println();
StartStampTankPH();
//StartStampReactorPH();
//StartStampORP();
CheckTankPH();
//CheckReactorPH();
//CheckORP();
Serial.println();
void CheckTankPH()
char inData[150];
char *inParse[150];
int index = 0;
int contador = 0;
char *str;
int count = 0;
Open_channel(ph1);
delay(50);
do
index++;
if (inChar == '\r')
contador ++;
if(contador == 23)
contador = 0;
inData[i] = ',';
char *p = inData;
count++;
PHA = 0;
PHA /= 8;
Serial.print(PHA);
Serial.print(", ");
Serial.print(", ");
Serial.print(", ");
Serial.print(", ");
Serial.print(", ");
Serial.print(", ");
Serial.print(", ");
Serial.println();
void CheckReactorPH()
char inData[150];
char *inParse[150];
int index = 0;
int contador = 0;
char *str;
int count = 0;
Open_channel(ph2);
delay(50);
do
index++;
if (inChar == '\r')
contador ++;
if(contador == 23)
contador = 0;
inData[i] = ',';
char *p = inData;
count++;
PHR = 0;
PHR += atof(inParse[i]);
PHR /= 8;
Serial.print("Reactor pH: ");
Serial.print(PHR);
Serial.print(", ");
Serial.print(", ");
Serial.print(", ");
Serial.print(", ");
Serial.print(", ");
Serial.print(", ");
Serial.print(", ");
Serial.println();
void CheckORP()
char inData[150];
char *inParse[150];
int index = 0;
int contador = 0;
char *str;
int count = 0;
Open_channel(orp);
delay(50);
do
index++;
if (inChar == '\r')
contador ++;
if(contador == 23)
inData[i] = ',';
char *p = inData;
count++;
ORP = 0;
ORP += atoi(inParse[i]);
ORP /= 8;
Serial.print("ORP: ");
Serial.print(ORP);
Serial.print(", ");
Serial.print(", ");
Serial.print(", ");
Serial.print(", ");
Serial.print(", ");
Serial.print(", ");
Serial.print(", ");
Serial.println();
Open_channel(ph1); // Tank pH
delay(1000);
delay(1000);
delay(1000);
void StartStampReactorPH()
Open_channel(ph2); // Reactor pH
delay(50);
Serial3.print("E");
delay(1000);
Serial3.print("L0");
delay(1000);
Serial3.print("C");
void StartStampORP()
Open_channel(orp); // ORP
delay(50);
Serial3.print("E");
delay(1000);
delay(1000);
Serial3.print("C");
switch (channel)
case 0:
//open channel Y0
//S0=0
//S1=0
break;
case 1:
//open channel Y1
//S0=1
//S1=0
break;
case 2:
//open channel Y2
//S0=0
//S1=1
break;
case 3:
//open channel Y3
//S0=1
//S1=1
break;
return;
